Np241 Growling
Discussion in 'The Garage' started by Guss, Dec 18, 2005.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    90 BLAZER W/ REBUILT 700R4 REBUILT 12 BOLT REAR AND NOW SOMTHING IS GROWLING IN THE T-CASE AREA IM ASSUMING ITS THE T-CASE BECAUSE EVERYTHING IN BETWEEN IS NEW COULD ANYONE HELP???
    CAN YOU BEEF UP THE 241 AND IF SO PLEASE SEND ME IN THE RIGHT DIRECTION. EVERY TIME IM GONNA LIFT IT I HAVE TO PUT MY FUNDS ELSE WHERE.:doah:
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    could be your chain, forks, broken snap ring, but all very easy to fix and parts arent too much either. unless you killed your planetary which I highly doubt. You might want to think about a slip yoke eliminator because the slip is the weakest point on a 241 and the kits are about $345.00 from ORD.
  3. Guss
    Feb 6, 2005
    78
    houston
    you dont know where i can get a parts break down and slip yolk eliminator?
  4. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    offroad design
  5. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Here you go.
  6. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Check the fluid level. That's what was wrong with mine.
  7. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Had the same thing happen to me. My TC had a slow leak. Had the seal replaced and topped off with new fluid, no more noise
  8. Guss
    Feb 6, 2005
    78
    houston
    thanks ill check the fluid didnt see any leak or seepage but ill check thanks again for all the info.
