NP241 not engaging 4-lo
Discussion in 'The Garage' started by zcarczar, Aug 21, 2004.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Well we got my t-case in but the damn thing wont engage the lo range planetaries, all it does is partially engage then pop out. I fiddled with it for a while today and i eliminated the shifter as the problem because it wouldnt fix it if i disconected the linkage and shifted it front the bottom. Anybody else had this problem? I think its something internal but I dont know what and I dont want to pull the case out again for no reason.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Inside they are similar to np208's and have the plastic pads on the range fork that wear out , and once worn , they eat away at the range fork until its knife-edged . Thats all I know about it . There was a rebuild in a mag a couple years back , maybe I can find it and scan it for you /forums/images/graemlins/k5.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Check your fluid level.
  4. zcarczar
    Feb 10, 2002
    2,495
    We just had the case out and apart to reseal it and weld up a small crack. So I wonder if its assembled wrong. The shift forks are good, and my fluid level is full.
  5. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I'd say it's a range fork or a range collar problem. Either the range fork is too worn to fully move the collar into the planetary or the teeth on the range collar are worn too much.
    The range collar is a fairly weak area IMO...
    Rene
  6. zcarczar
    Feb 10, 2002
    2,495
    Crap, I geuss I will pull the case down again, this will be the 3rd time for this case in a month. I should order a SYE kit for it while im at it.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you can afford it , by all means do it . Its a good idea , and allows you to get home if your shaft , and spare shaft break . My other Blazer will eventually have a fixed yoke case of some kind also /forums/images/graemlins/k5.gif
