NP241 questions, please help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by obrut, Jan 13, 2001.
  1. obrut
    obrut Registered Member
    Jul 27, 2000
    43
    IL
    I have a NP241 out of a 88 chevy full size truck (manual trans). I'm putting this into a different truck and need to know how to hook up a manual speedo. This t-case has i believe and electronic drive. Does someone sell a conversion? is there something i can get from a junk yard? also does anyone sell a SYE kit for this t-case? what would i expect to pay for a SYE?
  2. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    your tough out of lusk it only has a magnetic pickup.you should had a np208.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It should be mechanical. The first year for electrical was '90 i think.
    90K5
  4. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    The electronic speedo drive started from `90. So it won`t be a problem for you.
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  5. obrut
    Jul 27, 2000
    43
    IL
    Well if i'm not mistaken the speedo drive is on the t-case. My t-case has to electronic connectors on it one is on the case just right of the front out put (looking down on the t-case with the rear out put at your feet) and the other is on the tall shaft housing. This t-case is out of a 88 chevy pickup truck, manual trans i don't know if this makes a difference or not. I don't see any other spots to connect anything else besides the shift leaver. So what do i do then? What are the two electronic connections for?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    One of the connectors is for the 4x4 light, I don't know what the other one is.
    90K5
  7. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    The front one is your 4x4 light and the back one is for the speedo. If you take the back one out and look inside you will see a 40 tooth exciter ring.
  8. obrut
    Jul 27, 2000
    43
    IL
    So if i pull it out can i just put in a manual one? does anyone know what i need to do to make it work with a cable?
  9. azjimmy
    azjimmy Registered Member
    Sep 22, 2000
    80
    Battle Creek, Mi.
    Good luck! I don't think there's a gear in there to drive a mechanical speedo, but I could be wrong. Pat
    <font color=red>Don't sweat the small stuff, and it's all small stuff!</font color=red>[​IMG]
    '76 Jimmy, 6" w/35's 4.88's and all locked up
  10. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    There is not a gear in there to run a cable speedo. I just went through the opposite trying to get a cable drive NP205 case to work with my electronic speedo. I had to have an exciter ring machined and the housing tapped for the VSS. There is no way to make your case work with a cable drive speedo short of replacing the tailhousing and possibly rear output with a cable driven version.
  11. obrut
    Jul 27, 2000
    43
    IL
    Can i use a tail section from a dodge? there has to be some way to fix this
  12. obrut
    Jul 27, 2000
    43
    IL
    Will a tail section from a blazer 241 with a manual drive bolt up to my 241?
  13. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
  14. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Why not just install the speedo unit in the tranny, much like a 2WD application???
    ken
