NP241 Questions?
Discussion in 'The Garage' started by 78burb, Sep 13, 2006.
  1. 78burb
    78burb Registered Member
    Nov 6, 2003
    9
    Have a 1990 Sub with NP241 with the VSS. The 241 is shot-last snap ring gave out and totaled the inside. Having a hard time finding a 241 locally with the Vss but can get a 241 with mechanical speedo.
    Question can you swap parts between the two to make the mechanical to electric? Any help would be great. Thanks
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
  3. 78burb
    Nov 6, 2003
    9
    Thanks for the reply. That would work except I have the 1/2 ton version so I don't think the input splines are the same.
  4. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    the input spline part will swap out. its the output stuff you need.
  5. 78burb
    Nov 6, 2003
    9
    Upon further tear down of my 241 I find a cracked rear case, chewed up output shaft, bad chain, plus screwed shift forks. So thanks for the replies but hopefully I can figure out my original question. I imagine the housing that holds the vss is the same pattern as a mechanical one but would the reluctor ring or whatever it is called work on a mechanical speedo's output shaft? Thanks
  6. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
