NP241 same bolt up as a NP208?
Discussion in 'The Garage' started by TanMan, Mar 7, 2002.
  1. TanMan
    TanMan Registered Member
    May 31, 2000
    35
    NE Ohio
    Can anyone tell me if I want to swap in a NP241 in place of a NP208, if the bolt up is the same or not to a TH700R4? Is there any difference in the transmission to tranfercase adapter?
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Same bolt pattern assuming you get the same input spline count for whatever transmission you have. Watch for 241 version with mechanical speedometer hookup, later ones were for electronic hookups.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I think 89 was the only year for the 241 with a machinacal speedo.
  4. chevotaman
    chevotaman Newbie
    Nov 3, 2012
    4
    1988-1993 np241c
    Hello tanman,During 1988- 1993 the NP241C has a circular 6 bolt pattern and you will need an adapter for the 700R4 tranny.So if i were you i would look for a pre 88 model but beware because GM made both a right and left hand drop with mechanical speedo.I have a NV3500/241C out of a 1991 K1500 and i am trying to put it in a 1982 toyota 4x4.The NP241 i have is a left hand drop and i need a right hand drop T/C whether i can find a right hand drop 241C case or find an adapter for the NV3500.The engine is a built 383 with around 500 HP so i have to be careful as well.The only GM fullsize i have found thus far with a NP241C right hand drop is the 1989 surburban.If you have any ideas holler at me at my gmail.I hope i shed some light on your issue .chevotaman at coopercraig62@gmail.com
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Holy hell old thread batman. :eek1: I would certainly hope that 10 1/2 years later he found the answer to his question.
  6. Stomis
    Stomis Professional Amateur Premium Member
    Nov 20, 2007
    10,009
    237
    Roseland VA/PtPleasant NJ
    There needs to be mod approval to necro a thread after say a couple years or so...
    :doah:
  7. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    hey he's a nOOb with two posts.... give him a break......:haha:
  8. xenomarine
    xenomarine 1/2 ton status
    Sep 12, 2009
    1,067
    Southington, CT
    Necro-tastic. But, you can also get mechanical speedo 241 out of an 89 blazer
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yep, and I have all of the required pieces to convert a vss 241 to a mechanical speedo since I went from mechanical to vss. :D
  10. chevotaman
    chevotaman Newbie
    Nov 3, 2012
    4
    Hey yall, I th0ught the date on his post said 2012,not 2002.My bad.I am new here and i am trying to find my way around the site.By the way,the only 241C T/C i found" by locater" with a right hand drop for my chevota is in houston for $360 plus shipping.I think I will keep looking.Later,chevotaman.
  11. xenomarine
    Sep 12, 2009
    1,067
    Southington, CT
    what are you looking to do with this transfer case? SYE kit?
