NP241 (swap from 208) follow up questions...
Discussion in 'The Garage' started by foxman, May 14, 2004.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    It's my understanding that the output shafts on the np241 and 208 are the same.
    The 241 I have is off a 90 so I'm guessing that the 208 tailhousing will bolt right up to the 241 case and the spedo gears will match up accordingly...
    Where do I get replacement speedo gears for my 208 tail housing (which will be on a 241 case) to correct the speedometer reading?
    Thanks for the help.. looking to change the name to red soon!!!!
    Jeremy
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 208 tail shaft WILL NOT bolt up to the 241. its way different.
    the speedo gears will interchange, i have not seen a electric speedo 241 so i don't know if you can swap the sensor with the gears
