NP241 TH400
Discussion in 'The Garage' started by 4wsre69, Apr 20, 2003.
  1. 4wsre69
    4wsre69 Newbie
    Apr 20, 2003
    3
    Gaines, MI
    Can anyone tell me what I need to mate a TH400 from a 2wd Suburban to a NP241 from a 91 4wd Silverodo? I know I need an adapter and new shaft. Do I need any other items? Where can I buy everything I need?
    Thanks,
    Bob Hiller
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is that a '91 Silverado, as in Chevy pickup truck? If so, the first thing you'll need is a front axle from a Ford truck, to match the drivers side drop of that 241. /forums/images/graemlins/eek.gif GM IFS trucks have the front diff on the drivers side, while the solid axle trucks have the front diff on the passenger side.
  3. 4wsre69
    4wsre69 Newbie
    Apr 20, 2003
    3
    Gaines, MI
    This is a very special vehicle I am building, It has Front and rear Independent suspension. Maybe I posted to the wrong list but one of your members told me I could find answers here. Still need to find out how to do the TH400 NP241 connection.
    Sincerely,
    Bob Hiller
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    wel, as long as the th400 has the 4x4 output shaft, and you have the correct factory adapter(88-91 K2500 or even a 1h400 to np208 adapter) it should be straight forward. That combination was used from the factory in 88-91 k2500's so it shouldnt be to hard to do.
  5. 4wsre69
    4wsre69 Newbie
    Apr 20, 2003
    3
    Gaines, MI
    The TH400 is from a 3/4T 2WD Suburban. Where can I get the 4x4 Output shaft?
    Thanks,
    Bob Hiller
  6. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
  7. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Try any local transmission shops.
    They should have some on the shelf. It's not that uncommon of an item.
