NP241 Tranfer (4AUTO)
Discussion in 'Parts & Trucks Wanted' started by Greg, Dec 19, 2001.
  1. Greg
    Greg Registered Member
    Jan 17, 2001
    14
    Northern Va.
    Hey guys,
    as the subject line suggests, I need a NP241 Transfer case for my '90 blazer. I swapped out the manual tranny with an automatic however found out (the hard way) that THERE IS a difference between the manual and automatic versions of the 241. The spline counts are different so I need one for an automatic. will buy or trade whichever you prefer.
    Lemme know!
    Greg
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Greg
    I have a 700 to 241 adapter only (no t-case) for sale or trade. Let me know if you run across a t-case without one. I'm open to trades. What ya got ?
    Also have a rear shaft with slip stub from a 89 blazer that had a 700 & 241in it.
    Its a one ton jeep thing
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Greg, I am assuming you need a 27 spline 241 and you have a 32 spliner? I have a 27 spline gear that I will trade you straight across for your 32 spliner, or $50 by itself. Then, all you need to do is split the 241 in half and install the 27 spline input gear, not a big deal, about an hour job. Let me know.
    ken
  4. Greg
    Jan 17, 2001
    14
    Northern Va.
    Ken I'll be honest with you, I have no idea how many splines I have on mine! What I do know is that It came stock with a M465 4spd tranny and I swapped it for 700R auto. If yours originally came from a 700R4 tranny then I think we're in business. Let me know if it is and we'll work out the details. Another thought, I have to change the slip yoke portion of the rear driveshaft as well since it too is splined for a manual tranny. would you be interested in swapping that too? we will both need to replace the u-joint but that's pretty cheap considering.
    Also in case you're wondering, my blazer *just* rolled over 100k a few days ago. the only offroading it's seen is logging trails here in VA. Lame I know, but I mainly use it for family vacations and commuting in winter.
    Greg
  5. Greg
    Jan 17, 2001
    14
    Northern Va.
    I'll get back to you on the adapter. I'm still looking to see if I can hook up with a 241 transfer for an auto. If I can score one I'll let you know. Might just say the hell with it and put in a 208 instead. seems to be more out there.
    Greg
  6. promudder1
    promudder1 1/2 ton status
    Nov 18, 2001
    208
    i have a np241c from a 89 suburban for $275.00 to your door it is currently connected to a 27 spline turbo 400 if you want it all $350.00 to your door includes adapter and crossmember,otherwise the adapter and crossmember stay with me just lemme know
