NP241 TRANS CASE,
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Jan 23, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    IS IT ANY GOOD OR IS THERE A BETTER ONE I CAN USE? MINE IS BROKEN AND I NEED TO REPLACE. EXISTING IS NP241
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Very good t-case. Really low low-range (2.72) better than the other gm cases. Can handle tremendous torque - they are put behind Cummins Diesels (I think). And, they are light-weight. Only cons I can think of are the slip-yoke, and the aluminum case (read: breaks apart if you smash a rock). Some may suggest the NP205 for it's well-known strength/availablility...and that's an option you may want to consider if you can find one for a good price.
  3. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    WILL IT BOLT RIGHT UP? /forums/images/graemlins/confused.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    What, the NP241..yeah, as long as that's what is in there now. As for the NP205...I'm not sure. You may need an adapter of some sort. What tranny is it going behind?
    COULD YOU PLEASE TURN OFF YOUR CAPS, IT GETS BOTHERSOME TO READ...thanks.
  5. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Sorry, Its going on a 700r4. it had a 241 but it broke.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what made it break ?
