NP241
Discussion in 'OffRoad Design' started by stylin6, Jul 2, 2002.
  1. stylin6
    stylin6 Registered Member
    Apr 1, 2002
    40
    Kansas
    Does ORD sell a fixed yoke conversion for the NP241? I am putting this in a 70 Suburban and need to convert both the front output shaft and the rear, to fit the the fixed yoke axles on the truck. Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I don't know if ORD sells it but Jesse at high angle driveline does. The NP241 uses a sagina front shaft whereas the 203 uses a spicer shaft so you will need to do some driveline work.
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i think the fronts are interchangeable . mike<borregoK5 >
    has a 203 and it has a saginaw flange. if it is anything like a 208 either it should be swappable to almost anythign with the same spline count ,-32 i think ?
