NP261 on my 83?
Discussion in 'The Garage' started by Blazn83, Dec 17, 2006.
  1. Blazn83
    Blazn83 Registered Member
    Dec 11, 2006
    54
    Mechanicsville VA
    I was inspecting my leak, when I noticed that 261 was clearly stamped on the tag. I am 99.99% sure that no one has ever swaped out the transfer cases.. as it's painted OEM blue, like the rest of the drive-train.. can anyone explain?
  2. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    If it's painted blue, then the whole drivetrain has probably been out at some point. None of my 82 and up stuff was anything but black, and I've never seen one of the aluminum transfer cases painted.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    GM NEVER painted auto trannys or T-cases. I'm going to say that someone has been messing with it in the past and who knows what they've done.
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Its prolly the ratio stamped in the wrong location. Check under "ratio" on the tag and see what it says.
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    x2. The low range ratio is 2.61 and stamped in the tag. It's a np208.
  6. Blazn83
    Dec 11, 2006
    54
    Mechanicsville VA
    Heres some pictures of the transfer case. Maybe someone can identify it..
    (It clearly says 261?)
    some casting numbers if they are of any importance..
    img]http://memimage.cardomain.net/member_images/5/web/2525000-252[/img]
    The blue transmission.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    definitely looks like a 208 to me
  8. Blazn83
    Dec 11, 2006
    54
    Mechanicsville VA
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It is a 208 2.61:1 is the low range ratio and a NV-261 is a drivers drop HD case in the '99 up GM trucks.
    Ira
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Definately a 208 with a 2.61:1 low range with a production date of 4/13/83
