NPT searching help
Discussion in 'The Garage' started by Citizen Rider, Nov 17, 2006.
  1. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Goldwing2000 gave me the idea to use 1/4" NPT for axle vents as mine are missing.
    I did some searching on Jegs and found the 1/4" NPT to barb fittings, but taps are no where to be found.
    Where do i find a 1/4" NPT tap?
    Thanks in advance
  2. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    Home depot will have taps and fittings, you may even be able to use 1/8'' NPT fittings, those holes are usually pretty small. Most better parts stores will have fittings and taps as well, no need to mail order those kind of parts.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1/8" NPT should be more then plenty for vent lines. You should be able to pick up an 1/8" NPT tap & fittings at your local hardware store or Napa.
    Harley
