nu rear wheels or spacers?
Discussion in 'The Garage' started by bigbarbero, Mar 10, 2006.
  1. bigbarbero
    bigbarbero Registered Member
    Nov 12, 2005
    11
    ny
    91 burbby stock rim 35x12.5,front n rear.what would be better cheaper? want the front and rear even.i know that i could use 1.5 inch spacer,safety issues? or wider rear rim and how much offset.i plan on powder coating my front rims black,and buying black rims for the rear,but how to make them look even with the front is the question.other choice would be spacer's and powdercoating all four rims.btw street use only,N.Y. potholes
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    when spacing the rear wheels, i believe it takes away from your turning radius. why do you really want to do that? especially on a Burb, in NY? :confused:
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    best way to even out the front and rear is definitely spacers. Running different rims front/rear is just silly. You can't rotate tires, and what size rim would your spare be? Pretty much screws everything up. Just get some 1.5" spacers from Perf wheel and you're set.
    j
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Making the rear as wide as the front will increase your turning radius.
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    ...and increase stability and make the front and rear track exactly the same way...
    j
  6. goldwing2000
    goldwing2000 Guest
    So GM designed millions and millions of trucks that way for the sole purpose of making them unstable?
  7. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    :rolleyes:
    No, they designed them that way as a compromise... to get a slightly tighter turning radius. To get that, they sacrificed some stability (prolly not much, but its still some) and the front/rear tracking in the same path.
    j
  8. bigbarbero
    Nov 12, 2005
    11
    ny
    no doubt j brown,spacers it is
