nuetral saftey switch
Discussion in 'The Garage' started by big83chevy4x4, Mar 9, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i can't find my scematics, can this be left unpluged and still start? also which one is the nuetral saftey switch and which is the reverse light switch?
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Not sure... but on my K5 the switch is broken. Wont start in nuetral, and I have no reverse lights. Its towards the bottom of the colum. I thinks its one unit though. Sorry I wasn't able to help ya out last weekend... that last weekend was crazy
  3. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    no, the switch closes the circuit, so it won't start if it's unplugged unless the wires are jumpered together. Both switches are the same part, and you can get a new AC one for about $10 - $15 at the parts store.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im doing an auto to manual swap, so i don't need a new switch. ill have to figure out something then.
    thats ok jess, i only have a few things left to do.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i tried to change the plug to fit the clutch switch, but i destroyed the old plug, so i took the switch off the auto column and plugged in the wire and zip tied it to a wire loom way up in the dash. works just fine. this was if i get another one i can still swap them over.
  6. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I have a paper clip as a jumper in mine, its on the clutch pedal assembly.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i always jump mine together with crimp connectors,,,
    especially in the 4 speed trucks, and any that ive swapped to auto from manual
    its real simple to do,
    good luck
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Jumped mine too after the auto to manual swap.
