Null modem cable... what about null LAN? **update**
Discussion in 'The Lounge' started by Seventy4Blazer, Nov 17, 2005.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, so now i have the cable, but dont know how to se everything up. in the old days i would just set up a null modem connection... i dont know how to do a null lan connection...
    thanks
    Grant
    can i just twist a LAN cable like a phone line and do computer to computer?
    thanks. Grant
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can buy cross over cable to do NIC card to NIC card. That stuff is expensive though. I don't remember what the difference is i know i used my normal cat 5e cable and change the wires around and it worked
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    wire one side to 568a, and one side to 568b (switch pairs 2 and 3) and you're golden
    33211244 is the pairs one one end,
    22311344 is the pairs on the other end.
  4. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    here is the color code you want
    side a:
    white green
    green
    white orange
    blue
    white blue
    orange
    white brown
    brown
    side b:
    white orange
    orange
    white green
    blue
    white blue
    green
    white brown
    brown
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    cool thanks
    grant
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    If you're running XP, you're going to have to configure each machine with it's own IP address, and disbale the firewalls, too.
    If you're running earlier OS's, you can add the netbeui protocol and just go.
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    cant you just run NETBEUI on xp for a simple network? I know the protocol is in the machines and it would work fine for a little network like that i would think.
  8. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Netbeui was removed from XP. You can install it, but it's a pain in the arse and you need an install CD, the drivers are in some bonus folder on the cd. At that point, it's just easier to configure IP.
  9. zcarczar
    Feb 10, 2002
    2,495
    That makes sense, I guess if your a newb NETBEUI might be easier, but after working with a quite a few networks its easier for me to setup an IP based network.
  10. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ttt, need help setting it up, where do i go?
    Grant
  11. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    just make sure you use internal ip address ranges. and make sure your subnet is set to 255.255.255.0 and you should have a TCP/IP network very quickly.
    10.x.x.x
    172.16.x.x
    192.168.x.x
    and there is no NEED to disable the firewall ... but I guess there is no real need to leave it on either.
  12. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i got it working, thanks. had some help VIA PM. i had to disable my Mcafee to get it to work, but no big deal. then i transfered all my music from my lap top to my desk top.... now i need a larger HD... looks like its time for an external USB Drive now....
    Grant
