Numbers on the frame?
Discussion in 'The Garage' started by Chevy305, Mar 24, 2007.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    486
    New Hampshire
    So I just happened to be inspecting the frame for any more cracks and I found a whole bunch of engraved numbers. Located about dead center of the frame on the outside of the frame just at the height of the lip on the gas tank. Is this a partial VIN #? The frame had the exact same numbers on the opposite side too.
    This is how they appeared on the frame:
    14053532
    3 062 O1
    Can someone explain what these #s are?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    My guess would be partial VIN. Go look at your VIN number and see if they match.
  3. Chevy305
    Jan 23, 2006
    11,229
    486
    New Hampshire
    Ya thats why I want to decode this number because I don't have the whole VIN on the dash of my truck and I'd like to learn more about my truck. Maybe even try filling in the rest of the VIN numbers to run it through Carfax or something.
    My truck must have a salvaged VIN that the state of Massachusetts had assigned the truck some years back, and I'd like to try to understand when that was and why it needed a slavage VIN. Also I'm just currious as to where the truck came from and what options it had back in '85 when it was new.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Your state modifies the VIN if it was salvaged?
  5. Chevy305
    Jan 23, 2006
    11,229
    486
    New Hampshire
    No the VIN plate is totally missing. So MA put a little tag in the door jam with some 6 digit number that is to be used as the VIN in paperwork like on the Title, registration, and insurance.
  6. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    I think that 140 number might be a part no.?
  7. Chevy305
    Jan 23, 2006
    11,229
    486
    New Hampshire
    A part number? For what, the frame?
  8. 76zimmer
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    yep, everything GM makes has a part no.
    I'm thinking that looks like a lot of 140......numbers they use for part no.s
  9. Chevy305
    Jan 23, 2006
    11,229
    486
    New Hampshire
    I searched the number in GM Parts Direct and nothing came up.
    But I have heard that there are partial VINs on frames so then where would that number be?
  10. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
    You guys think there would be a problem covering up those numbers?
  11. 76zimmer
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    I don't even know if it exists....
    The 140------number looked like a part # to me.
    I've looked for frame part #s and VIN #'s but don't get info on either.
    See if this makes sense with the numbers you've found
  12. 76zimmer
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    I would grind them off if your concerned about wrong #'s
  13. Chevy305
    Jan 23, 2006
    11,229
    486
    New Hampshire
    I see your point there...
    The number doesn't seem to match up too well with any VIN decoders.
    Anyone here know for sure what those numbers are?
  14. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I know you used to be able to order the whole frame from GM it might be a S.P.O. number. As long as you have paper work from the state don't worry about it unless you know more than you are saying. Just leave it be!
    If you start grinding numbers off it will look like you are hiding something and will get MORE attention!
    By Federal law the number, or partial number must be on the vehicle in 7 locations. Most are kept secret.
    I will give you one place to check!
    Stamped into the top of the frame, on the passenger's side, right below the firewall.
  15. 76zimmer
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
  16. justiz00
    Dec 11, 2006
    83
    Central Texas
    Nothing to hide, just questioning thier purpose. The numbers on the top of mine are CE.... stamped twice about 8 inches apart. My old Luv truck had the vin on both sides behind the front fender marker lights.
  17. Chevy305
    Jan 23, 2006
    11,229
    486
    New Hampshire
    Thanks I think I found what I'm looking for:
    Well I don't want to be grinding off any numbers. I already have all legal paper work and the state assigned VIN, so nothing I'm doing is illegal. I was really just looking for a more complete history of my truck. When I have enough time I will drive over to the DMV and ask them to pull up the records on my truck. I know that my truck is no where near original and I would like to know exactly where all the components come from. According to the PO the entire chassis is an 85, the grill is an 84, and the bed is mostlikely a 74. Through other research and familiarizing myself with the 73-87 Chevy trucks I found most of that to be true. Except the engine is from a 83 Firebird (ran the engine numbers)
    I will go look right now for that number on the top of the frame. :D
