Nutts on raised steering arm
Discussion in 'The Garage' started by MUD JUNKIE, Apr 29, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    I was told after you remove the nutts for the half horse shoe steering arm they must be replaced.If this is true,what are the names of these nutts,or where could I pick some up? /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    You can reuse them, just use locktight when you reinstall them. /forums/images/graemlins/k5.gif
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    They are called anti back off nutts, or sweged nutts.
    Sometimes they will use nylon as the anti back off part of the nut.
    And usually they are grade 8 nutts.
    Go to a nutts and bolts screw store.
    Good luck
  4. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    umm,I think they are called nylock nutts? is this the right kind? if so I'll get them today
  5. Executioner
    Feb 22, 2000
    1,530
    I have only seen about 1200 steering arms, and all the
    ones I have seen had used a Swedge Design, but
    I suppose you could use Nylon .
  6. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    swedge design? what is that?
  7. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    it is a slightly oval shape where the thread exits the nut, so when the threads go through they have to "push" the oval to round shape and this tension helps hold it in place
  8. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    I see,I will ask for those when I go to the hardwaree store
