nv4500/205 Twin stick help
Discussion in 'The Garage' started by 1967k10, Jan 16, 2006.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    I 'm trying to install a Twin Stick on my 4500/205 combo and having a hell of a time.I got it with my nv4500 but it sure isn't made to fit.I've modifyed my tailhousing and built a new piece for the stick to move the inner rail with.It still isn't working worth a crap. Which rail do I need to grind?, the inner one right? Need to get this going asap.
  2. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    I had to modify mine yesterday. I have an nv4500 mated to a np205 with no adapter. If your problem is the pins don't go into the levers on the np205, I can help.
    EDIT: Sorry, read this wrong. You are grinding rails, mine were already installed.
  3. 1967k10
    Nov 21, 2005
    1,728
    Yes I'm grinding the rails.I already ground the inner one.That's the one I was told to gring.It appears I will have to do some more mod's to the talihousing.I don't have an adapter,just an AA spacer since I have a round pattern 205 with a long input shaft.
