NV4500 4x4 for GM
Discussion in 'Parts & Trucks Wanted' started by kennyw, Aug 24, 2006.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    deleted
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    1. I wasn't aware the early nv4500's shared the bolt pattern with the 465's, COOL!
    2. The 208/241 will bolt up to the nv4500 4x4 tailhousing- must be 32 spline
    3. I have a driver drop 241-electronic speedo, $250 shipped, or trade?
    Jimbo
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    My NV4500 is a '95 and the bell pattern was nothing close to the 465 pattern.
    Rene
  4. kennyw
    Jun 9, 2002
    13,223
    94
    I thought I had read they used the same pattern... :doah: Guess I have some more checking to do. But worse case I may just have to get the bellhousing with it. Just want a hydro bell with the external slave cylinder in the end and to have it bolt to a 6.2L.
    Since I already have a 32 spline NP208 I'm going to hold off on buying a tcase till I have a transmission in my hands. Will that electronic speedo work with aftermarket guages?
  5. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    What little I know about nv4500's, is that the bellhousing pattern is unique to them. Beware that your rig must be lifted if you're going to use an external slave bellhousing, as the slave is on the lower right hand side, and would hit the diff on a stock application.
    I don't have any idea whether or not the electronic speedo will work with aftermarket guages--probably could be adapted.
    What is your driver drop 32 spline 208 out of? I thought GM used 241's on the new body style 88 up 4x4's. Just curious, always need more information.
    Jimbo
  6. kennyw
    Jun 9, 2002
    13,223
    94
    :doah: I meant to say PASS drop :haha: Going into a stock '85 Chevy M1028...
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I used a bell from Advance Adaptors. It's machined for a Jeep application slave cylinder on the drivers side. The bell itself was $400 or so...
    i looked for a factory bell for a while, but most every truck that hits the wrecking yard was hit hard enough to break the bellhousings. :doah:
    The only part the NV4500 shared with the SM 465 was the input housing diameter.
    Mine will be going together real soon here, send me a pm and I'll give you all the details of what I ran into as far as what worked and what was a problem.
    Rene
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    it is very possible to drill/machine the sm465 hydro bellhousing to work, crawlinK5 has one
  9. kennyw
    Jun 9, 2002
    13,223
    94
    And I'd probably do that first before spending $500 on a new bell...
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I had a 465 bell I trial fit on the front of my NV4500 and two holes looked possible, one was in a terrible spot, and one was not even on the bell.
    Maybe the hydro bell's are different?
    Rene
  11. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    Numerous guys have re-drilled the 465 bellhousing to fit an nv4500. All 465 bellhousings are the same to my knowlege. I have a mechanical one bolted to a 91' 465.
    Kenny: I have a 99' hydro bellhousing but it's the internal slave. Supposed to be better or so I was told when I bought it. It fits 96'+ trannies. Let me know if you end up needing one.
  12. kennyw
    Jun 9, 2002
    13,223
    94
    Would be better for space, and would fit the Dodge cummins tranny I found locally... but I don't like the idea of having a slave leak and wreck the clutch. But the Dodge NV4500 I found is cheap and in need of a rebuild anyway. So I will have to think about it, may go that route to keep it simple and keep the cost down.
    How much do you want for the bellhousing?
  13. BowtieBlazer
    Jul 15, 2001
    2,462
    my thoughts exactly and if you have to change or trouble shoot the slave its right there in plain sight
  14. 1967k10
    Nov 21, 2005
    1,728
    I'd take $125 for it. I also have a new GM input,bearing,and retainer that we took out so we could run a GM nv4500 behind a CTD in my brothers Chevy. They would be just what you need. I understand about the bellhousing and troubleshooting a slave leak.
  15. kennyw
    Jun 9, 2002
    13,223
    94
    I'll think about it... see what kinda deal I can find on a tranny and see where I have to go from there.
  16. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    I have to agree with the apprehension over internal slaves. I had a 98 Chev K3500, 7.4/nv4500; I finally traded it off after replacing the slave twice and the clutch once in 58K miles. Not to mention it was a dog.
    Jimbo
  17. 1967k10
    Nov 21, 2005
    1,728
    That's odd :confused: :confused: . I'd say something was wrong. I had a 97' 2500 7.4/nv4500 also and I abused the hell out of it,pulled 20K LBS loads of hay and it never let me down. Finally traded it at 148K. It ran like a scalded dog. Would spin the tires in 4 gears :D .
