nv4500 96-up hydro bearing style.
Discussion in 'Engine | Tranny | T-case' started by sweetk30, Sep 5, 2006.
  1. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i have a nv4500 from a 96-up 2x4 truck. fixed yoke style. has new frt and rear seal. also pulled cover and looked like new. slight dirty film. rinsed all out and ready for the 4 new qrt of correct oil i have also. needed new 5th/reverse pads on the fork. i will have them soon to install.
    the bad. the back cover had a puncher hole in it. i removed and found no problems. hole was from the outside in. broken part on truck caused it. i had the cover tig welded back closed by a pro.
    also the hydro throout is bad. will need new one.
    i have the bell housing to this tranny. the shifter is in hand also. complet with new rubber isolator kit and bolts.
    pm me and we can talk.
