NV4500 - Bellhousing bolt extraction
Discussion in 'The Garage' started by rcamacho, Sep 26, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    http://eshop.advanceadapters.com/commerce/catalog/product.jsp?product_id=1665
    I'm running an earlier style NV4500 with what appears to be an AA bellhousing. One of the allen head bolts is stripped at the head. I need to remove it so I can install the NP208 support rod that the PO left off. Any suggestions?:mad:
    I'd rather not have to remove the whole #%$ assembly to get at it but it's fairly tight quarters up there for a RT angle drill/extractor routine... Bolt is SS so tack welding with flux core is not very attractive.
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I have that exact bellhousing sitting behind me attached to my NV4500. I'm not sure I understand which bolt it is that is stuck though...
    If the PO ran some Stainless socket head cap screws into the 4 locations where the tranny and bell bolt together that's gonna be miserably tight to get to.
    Welding to SS is an option. A lot of SS can be welded with regular welding wire. For an extraction I'd try it...
    Rene
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    The hex head bolt appeared to be regular steel. I tried welding an allen socket to it this afternoon but it shattered when I hit it with the impact. Looks like I'll have to use the traditional extraction technique by drilling off the head and using an extractor on the rest. Yuk.
  4. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    Try using a squirrel socket
    __________________
    84 K5 350/700/208/14bff/10b
    Coming soon 465/205
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Check your Sears catalog; they have "screw out" and "bolt out" thingies that I've had decent luck with.
    Jimbo
