nv4500 bellhousing still need anyone???
Discussion in 'Parts & Trucks Wanted' started by sweetk30, Feb 11, 2006.
  1. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    i need one for a hydro throwout bearing style from a 95 or so and newer truck. thanks.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Are you repairing a truck or converting one? If its a conversion I'd stay away from the internal slave if you can.
  3. sweetk30
    Nov 1, 2004
    25,528
    527
    i am converting one. and thats what is on the tranny now. i found it in the junk yard like that. so i figurd it would be good. what is the big problem with these? i am a mechanic and havent seen to many bad things with them.thanks for any info buddy.
  4. kennyw
    Jun 9, 2002
    13,223
    94
    The problem is, when the slave cylinder fails it takes out the clutch with it unlike the external slave. Plus to repair it involves pulling the whole tranny first rather than unbolting it from the exterior of the bellhousing. May not be as big of a deal if your time isn't as important (plus a fully equipt shop takes a lot less time anyway).
    If it was my truck I'd be putting in the older hydrobellhousing with the external slave. Same one used on the SM465 works with the NV4500.
  5. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
  6. kennyw
    Jun 9, 2002
    13,223
    94
    Not that I know of on the NV4500 compared to a SM465... Still 4 bolts into the bellhousing. Had an NV4500 once but sold it before I had time/money to rebuild it and install... Never got around to putting it on a 465 bellhousing though.
  7. sweetk30
    Nov 1, 2004
    25,528
    527
    i was told thay went bigger and wider on the pattern.
  8. dyeager535
    26,975
    Kenny, still have that bellhousing from me handy? I think that has the hole spacing penned in. :) Would be handy if someone can measure the 4500's bolt pattern.
  9. sweetk30
    Nov 1, 2004
    25,528
    527
    i can measure pattern its in the back of my truck now.
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i can measure a 465 hydro bell if need be
  11. sweetk30
    Nov 1, 2004
    25,528
    527
    i have been looking on the other site called pirate:rolleyes: and thay say you need a adaptor plate to mate it to the 465 bell.
  12. kennyw
    Jun 9, 2002
    13,223
    94
    I've got 3 SM465 bellhousing handy...
  13. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    You do need an adaptor plate to make a 465 bell work. I put a 465 bell up against my NV4500 and there are one or two holes out in mid-air. I'll go and measure up the hole pattern on my 4500 in a minute.
    FWIW I'm going to use a bell from AA, it's $340 and saves me a ton of headaches.
    Rene
  14. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    Top holes are 10" apart, bottom holes are 4.625" lower than the top holes and are 10.5" apart.
    rene
  15. sweetk30
    Nov 1, 2004
    25,528
    527
    to the top please.
  16. sweetk30
    Nov 1, 2004
    25,528
    527
    still need one. :crazy:
