nv4500 brass syncros?
Discussion in 'The Garage' started by crawlink5, Mar 8, 2006.
  1. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    Does anyone know where I could get brass/bronze syncros for a nv4500?
    Has anyone done this and did it work well?
  2. sweetk30
    Nov 1, 2004
    25,555
    548
    horseheads , ny 14845
  3. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    I looked at that site and found no mention of brass/bronze syncros. I have seen one post where someone found and changed out 3rd, 4th, and 5th, but not 1st and 2nd.
    What's so special about this one that it has to have this special material?
  4. sweetk30
    Nov 1, 2004
    25,555
    548
    thay say that the cheep replacements are all brass. and dont last as long as the carbon fiber coated units. dont forget the carbon fiber is stronger .
    just a site for ya to try. but you have seen it already. good luck.;)
  5. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    Fiber may be stronger - as long as you go broke buying oil. You can't get the oil in a one horse town in the middle of the night or even in a big city in the middle of the night. At that cost I don't want to pack an extra 6 quarts.
    I just can't help thinking about the last 50 plus years of proven brass.
    But then again it may not work - just asking
    I forgot to add - I have two Carbon fiber syncros in the kitchen for 3rd gear. Brass with carbon fiber surface area on inside I.D. It may wear slower but I can change the brass out when needed.
  6. crawlink5
    Oct 9, 2003
    431
    Spring, TX
    Any idea where to get these cheap brass syncros?
    I'm in the nood for experimenting. It won't hurt the trans, at most I'll have to pull it out again and change them back out.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why would you want the brass ones? Also, you dont have to run the fancy oil. We put MTF in at work and we dont have problems. I think mine has ATF in it.
  8. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    We can get any transmission part you want, NV4500 brass synchos included.
    -Kyle
    NWF.
