nv4500 conversion info needed
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JoshA, Mar 25, 2002.
  1. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    I currently have a 465/205 setup. what is involved in converting to a 4500. anyone know of a site with a good walkthrough?
    thanks
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do a search to try and find a post where Steve Chin answered this same question. His web sight has some good info too...but most of it is in his head!
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    See: <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=354056&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=&amp;fpart=>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=354056&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=&amp;fpart=</a>
    That's a reasonable summary. If you have some specific questions, send me an email.
  4. JoshA
    Apr 9, 2001
    104
    slc,ut
    thanks, thats enough info to get me started...
  5. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Steve inspired me to make the switch and really helped me out with my install as well. I found that my AA adapter is configured slightly differently, and my crossmember had to go further back than Steve's. There is a lot of drilling to do, so "be sure"....
    JB
  6. Steve_Chin
    Mar 6, 2001
    1,126
    JB, how's it running? You got the AA tailstock instead of the Dodge one, right?
  7. JungleBoy
    Jan 31, 2001
    243
    Houston TX
    Steve
    It's not - yet. Engine in frame, setting up TBI. I got the GM trans from the guys you recommended, Discount Parts Exchange - a good savings over AA...
    Thanks again for your help.
    Josh
    My crossmember moved back 3-3/8", due to the configuration and mounting setup on the adapter... GM has all the mounting stuff new - cushions, locks, steel tubular inserts for TC brace on frame rail, etc... Everything but bolts, I think.
    JB
