nv4500 cooler
Discussion in 'The Garage' started by original balzer, Nov 19, 2004.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    cooler lines on a nv4500 anyone else herd this
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    4500 is a standard trans.It has no cooler.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    No, never.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Dunno what you are talking about, no cooler, and no provisions ot be able to hook a cooler up. (splash lubricated, no pump.)
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    doesn't mean it couldn't be done. I've read towing in overdrive isn't very advised cause of the excessive heat it causes /forums/images/graemlins/dunno.gif
  6. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Are you sure its heat realted? Towing in OD is bad because 5th gear is weak.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    isn't there a fix for the weak fifth gear?
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    take off the tail housing and change the nut. if its loose already gotta change the gear as well. the nut has an allen head in the side and locktite for it. iirc $45 from the dealer . quick fix
    69k5 /forums/images/graemlins/smile.gif
  9. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    There is also an improved mainshaft available with a wider splined section under the 5th gear to support it better. Spendy though ~300.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah, the nut with the allen bolt in it.
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Plenty of standard trannys have internal pumps and provisions for coolers. Just not anything you'd use in a light truck...
    But the root of your statement is correct; the NV4500 has no fittings for a cooler.
