NV4500 Diesel Vs. Gasser?
Discussion in 'The Garage' started by botboy, Apr 20, 2007.
  1. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Ok, so I'm debating whether I put a 465/205 behind my 6.5 in my crewcab, or spend the big bucks and put an NV4500 behind it.
    Doing a car-part search, looks like the NV4500 came behind a gasser and a diesel - what's the difference? Just a lower OD ratio, or what?
    Truck is an '80 C30 CCSB, originally a 350/TH400/2WD truck, when i'm done plan to have a 6.5 (Mech. PMD from '93 Cube van), banks kit, manual, 4x4 with a D60 up front....I got a lotta work ahead of me :D
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    No difference. Only difference was that 93-94 models, all of them, had a lower ratio. The only gearing differences in diesel vs gas is in the rear end.
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    The diesel version has a harmonic damper inside. My NV4500 is a '95 diesel version.
    The big round thing on the back is the damper.
    Rene
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    that must be a GM thing because my '98 Dodge nv4500 definately doesn't have anything like that.
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    It is a GM thing...and goes a long way to keeping 5th gear from coming loose.
    Rene
  6. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    that must be why the full splined mainshaft is the recommended Dodge fix.
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    Maybe, I do know the cause is 5th gear rocking against the nut. Heavy load and the transition between throttle and no throttle puts a ton of rotational stress on the gear...and being that it's not full spline it eventually can develop a bit of a play. That rocking motion against the nut loosens it off eventually.
    The damper on the GM version sits between the nut and the gear.
    I did carefully check the mainshaft on mine for any signs of fretting and saw none...so I put it together using a stock replacement nut.
    Rene
  8. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I stuck the updated pinch nut on mine, and welded it to the shaft. we'll see how long mine holds :doah:I've got fuel and air components coming to go over 600horse.
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    Cool (on the 600 hp part)
    My 6.2 will never be able to hurt the NV4500...;)
    Rene
  10. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    I believe the damper was a GM-only thing not specific to diesel. I have two NV4500's, one gas 6.34 and a diesel 5.61 and both have the damper.
