NV4500 DOUBLER ???
Discussion in 'OffRoad Design' started by SANDMAN500, Dec 27, 2001.
  1. SANDMAN500
    SANDMAN500 Registered Member
    Aug 6, 2001
    63
    Bend,OR
    Hey Stephen, is it possible? I hane a 93 1 ton straight axle project that really needs a doubler. Thanks..........Tony
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    been runing this in mine for 2 years now
    72 Blazer 400TPI NV4500 NP203/205, 6 bolt FF14
    01 Suburban 8100 2500 4X4
  3. SANDMAN500
    Aug 6, 2001
    63
    Bend,OR
    cool, what kind of adapter did you use to hook the tranny to the 203 range box. Or does ORD make an adapter that i will get when I purchase the doubler kit?
  4. blazer72
    Apr 13, 2000
    939
    KCMO
    I think you can just redril the face of the 203 then use the t400 input gear which is a 32 spine. You can also use the Advance adapter plate and the dodge tailshaft housing for the 4500.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Tim (tlarsw) is running the Doubler using the NV4500. Check out pics on his site. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The best way to bolt the 203 to the NV4500 at this point is to use the 32 spline input in the 203 and re-drill the face of the 203 gearbox to the round pattern that's on the back of the factory NV4500 GM 4wd adapter housing, then you can bolt them right up. One hole causes problems due to being near the edge of the casting but it's easy enough to move a little and make it work.
    Once the 203's bolted up you just do the Doubler like any other system and you're done.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  7. Dodger
    Dodger Newbie
    Jan 4, 2002
    Santa Rosa, CA
    Stephen:
    What about us Dodge guys? I've got a '95 Dodge NV4500 and a '75 Dodge NP203. I think they're both 23 spline. Will the redrill trick work for my setup?
    And if it will, is it an impossible task for the home shop? I guess there must be some pretty close tolerances as far as getting the two pieces centered correctly.
  8. SASQUATCH
    SASQUATCH Registered Member
    Oct 14, 2001
    36
    Tony,
    I lost your number, Please give me a call asap.
    Thanks, Sasquatch
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    For the Dodge, if they're both 23 spl. you just need to check the stickout length and you should be able to re-drill. The beauty of this is the bearing retainer on the 203 is identical or very close to what needs to fit into the 4500 adapter, so it indexes the shafts and the bolts just hold it together and set the rotation.
    SW-ORD
