NV4500 gear ratios
Discussion in 'The Garage' started by lrazer, Dec 2, 2005.
  1. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    anyone know what the gear ratios are in a NV4500?
  2. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    HTML:
               GM 93-94  95/up GM; 93/up Dodge
    First Gear   6.34  5.61
    Second Gear  3.44  3.04
    Third Gear   1.71  1.67
    Fourth Gear  1.00  1.00
    Fifth Gear  0.73  0.73
    Reverse     6.34  5.61
    For some more quick reference info check out this page. It's the first one that came up when I googled "NV4500 gear ratios" for you.
    http://www.high-impact.net/transmission_and_gear/nv4500.htm
  3. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
  4. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    thanks i found the same site just wasn't sure cus there were different gear ratios listed
    so the gm ratios are all the same and the dodge have different ratios?
  5. B_to_C
    Jan 15, 2003
    1,861
    :doah:
    In 1993 and 1994 GM had special gearing (the first column of ratios in my post above)
    Starting in 1995 all GM and Dodge trannys had the same ratios (second clumn of ratios I posted above)
