nv4500 install
Discussion in 'The Garage' started by hi pinion, Feb 28, 2006.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Just curious exactly WHO has done the swap, if they have lots of neat pics, etc etc. I looked in the wirteup section and all i get is a link to another link.NOPE! Common, who has it? Lets see it!!!
  2. hi pinion
    Sep 25, 2003
    5,354
    I knew nobody had done it:haha:
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    *rasies hand* On a first gen though, but you knew that.
  4. sweetk30
    Nov 1, 2004
    25,555
    548
    horseheads , ny 14845
    i am using a hydro throw out style from 96-up in my 79 k30 cab chassie. it is fixed yoke 2x4 so i will use my divorced 205 with it. basic bolt up and need to move the shifter hole back about 5" from what i have read.
  5. hi pinion
    Sep 25, 2003
    5,354
    Actually i had no idea, do you have any build pics? Good to hear from you again BTW.
    Jake
  6. hi pinion
    Sep 25, 2003
    5,354
    Anyone?
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    What the heck do you want a 4500 for? It's a wheeler, not an over the road traveler. You don't need overdive, so there....:p:
  8. hi pinion
    Sep 25, 2003
    5,354
    Yeah right the, NV4500 is a cool deal, who says you cant wheel with a NV???? :D
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Nobody said you couldn't wheel one, but it seems the main reason guys swap them out over a 465 is for the overdrive for better mileage as a driver. Both have the same gear spread anyway, wheeling either the 465 or 4500 should feel very similar from what I know, meaning I don't think there is much if any gains on the trail with a 4500 over the 465, it's cruising down the highway at 65mph and 2,200RPM's or so that is whats gained, and the main reason why people want them from what I know.
  10. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    NV4500 is cheaper than a trailer and tow rig...:D
    Rene
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Jake ill get you some pics.
  12. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    exactly.... i some day plan on a nv4500... yes I want over drive.... I drive down the highway at 75mph and the motor could be purring instead of almost screaming... my truck is what I drive to the trails and drive home..... I expect alot out of my truck.. plus I Know to limit my beatings and expect to drive it home... :wink1:
  13. jscurtiss
    jscurtiss Newbie
    Feb 7, 2006
    NE
    I also want to do the 4500 swap. But i use my rig more for tow.
  14. Snoozer
    Snoozer 1/2 ton status Premium Member GMOTM Winner
    Aug 10, 2005
    382
    17
    Colorado
    Exactly!
  15. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    I've done it twice Once on my K20 and once on my K10 stepper(actually this one is in progress) My k20 has a dodge NV4500 and 205 My k10 has a Dodge NV4500 and 241 Bothe fixed yoke from 93 dodge 3/4 tons (one cummins one 360) I used the bellhousing adapter from Advance Adapters . it's awesome My K20 Had aTbi 454 and 4.10's with 315-70's and I got nearly 15mpg Highway about 11 in town I DD it for 3 years until it got t-boned last summer My stepper Is stripped nearly to bare frame (still need to pull the cab) It will have an LT-1 Tpi In front of the NV4500/241 with 4.88's and 37" MTR's I'm hoping for simular mileage
  16. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,233
    491
    New Hampshire
    :bow: STEPSIDES :bow:
    OD would be very nice seeing how I like to drive 85ish which is like 3200rpms. That does a number on the engine after holding it at that rpm for an hour.
  17. yellowK20
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    yeah me to speed limit is 75 on the highways down here(and you get passed if ya don't run at least 80) So O/D is greatly helpful It's alot like driving a SM-465 (a bit smoother shifts) first gear feels the same as do the others. Stepside pichttp://pg.photos.yahoo.com/ph/yellowk20/detail?.dir=763d&.dnm=f6f2.jpg&.src=ph
  18. RootBreaker
    Nov 29, 2001
    5,118
    173
    what about the nv5600 instead of the nv4500? which of the 2 would be the easier choice.... lets put asside length, cost, availability....
    just trying to say.. would the nv5600 bolt up easier? I believe the nv4500 uses a drivers side output for the front shaft?????
  19. yellowK20
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    Well with the right adapter you can use any t-case you want any side drop you want I made my swap easier by using 93' dodge trans&t-case's with d-side drops as far asthe NV5600 there an intergrated bell housing they make kits but that's a big heavy tranny (like 360 pounds I think?) and the NV4500 is like 165 or so and all NV5600 came in trucks with a D-side drop
  20. RootBreaker
    Nov 29, 2001
    5,118
    173
    think im sold on the 6 speed now!!!!!!!! NV5600 in the future....
    I dont care about weight or lenght.. I got a fullsize....
    weight is merely a small factor.. you just bring that many less people that make that weight up....:haha:
    eventually when I do the crew cab conversion... the bed will be cut but I will still have the rollbar, toolbox with tools, oil, oilfilter, belts, chainsaw, straps, extra alt, waterpump, starter, dshafts, universals, axle shafts... kinda like a self recovery, self repair vehicle...
