NV4500 is the BEST!!!!
Discussion in 'The Garage' started by K5MONSTERCHEV, Aug 14, 2003.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    So I got my NV4500 installed last week, just intime to go up to Pincrest to go camping. It shifts so easy, the hydraulic clutch is really nice, and the best part is that I went from 7.5 mpg to 12 mpg!!!! And that was uphill. I know a little bit of the mpg increase is from putting on the 38's rather the 42's, but still. I am so happy!! What a difference OD makes!!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i take it you swapped that for your 465...how straightforward was the swap? are you lost without the low gear?
  3. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    How about more info??? I have a 88 crew cab with a 454 and 465 and would love 12 mpg. /forums/images/graemlins/eek.gif I've even considered the overdrive units.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    right on congrats /forums/images/graemlins/thumb.gif so how bad was the swap?
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Just make sure if you plan on pushing some power thru 5th to get the upgraded 5th gear. That seems to be the only weak link of the NV4500.
  6. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    i have heard the same thing /forums/images/graemlins/thumb.gif
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The swap was easy I got everything from a 93 chevy bellhousing, hydraulic setup, starter, tranny. Everything went good, I got the adapters from AA bolted the t case up tp he tranny. The chev nv4500 has a harmonic balancer on the back of the tranny and you have to take that off and cut the mainshaft down. Then theres a coupler that mates the tranny to the 205. I bolted it all up in the truck. AA had an adapter to bolt the tranny to the crossmember, which didnt line up, youd have to drill holes and move the crossmember back but instead we made a mounting plate, which worked perfect. I think the whole setup is about 1" longer, i have plenty of slip, and no vibrations or bind at full droop. 1 thing i fergot to even think of was the flywheel, It rubbed on the bellhousing but it has worn, so now its not noisy anymore. My tranny was a '93 so it still has a 6.34:1 1st!
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    someday I will do that one too... someday. I should right now while I am planning on tearing the K5 down and starting fresh but I know myself I won't do it.
  9. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    [sarcasm] You shoulda swapped in a 700R4..... bulletproof [/sarcasm]
    /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/grin.gif
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    no it isnt.... the NV5600 is the BEST... he he.
    im kidding man. i envy you. some day i will swap one in. but first i need to get it together and running with the 465.
    Grant
  11. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    how did you mount the clutch pedal? i got one out of a '94 with all the hydraulic stuff and am working on putting it into a 77, the thing is the brake booster is invading the space that the master? cylinder supposed to sit.
  12. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    sounds sweet! what is the difference netween the NV4500 and 4L80? which one is considered stronger and better? What years did they change model?
  13. Confedneck
    Nov 1, 2002
    5,236
    nv4500 is a 5 spd manual..4l80 is an auto
  14. Toledo
    Dec 10, 2001
    207
    damn I feel dumb.
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you use the pedals/master from the 85+ versions it puts the master lower and to the ds of the booster
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    well isn't that a given since 84 and back were mechanical clutches?
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I took the whole pedal assembly, which was at an angle, cut off the neutral saftey switch, and cut the corners out then made it square, so it would fit under the dash, and welded it back up. Then since the angle was taken out and not inline with the master, I made a different pushrod, one that was stronger, that went up into the master cylinder. The pedals not in line with the otheres anymore, so thats one thing im going to have to fix.. All you who are intrested, Ill tell you what. Im starting school tomorrow but give me a few days or so and Ill try and get pics of it all so you have a better idea.
  18. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Oh yeah, I did upgrade the 5th gear!
