nv4500 swap
Discussion in 'The Garage' started by odee, Jan 18, 2004.
  1. odee
    odee Registered Member
    Feb 5, 2002
    15
    Big Stone Gap Va
    I want to swap a nv4500 into my 2wd dually that I pull my jeep and racecar with.Has any one here done the swap using the 85 and up sm465 hyd. bellhousing? I was told that this bellhousing has both bolt patterns in it. thanks
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 85-91 SM465 bellhousing does not fit the NV4500. It only has the single bolt pattern. /forums/images/graemlins/frown.gif
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The 465 bell isn't even close when it comes to the NV4500. The bolt holes are so far off in a couple of locations it'd take some major work to make it fit. About the only thing the two tranny's share is the input bearing housing diameter...
    Rene
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is it possible to use the NV 4500's bell and slave, and simply hook the line to it and go?
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    on a 2WD...sure. On a 4WD there might be interferance with the front driveline though. The slave and junk is on the passenger side of the bell on an NV4500.
    Rene
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Eeew, yuck, I forgot, all the newer trucks are a driver drop front axles....why did GM do that?
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Musta hired a Ford designer in 88 or so /forums/images/graemlins/ignore.gif
    Rene
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Rene
    Right, but if your truck lifted a little, there might not be any problems, my slave doenst sit any lower then my 8qt oil pan. You can get the newer bellhousing with the slave in the belhousing.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the 85-91 sm465 bellhousing has 2 bolt patterns
    no idea what the second pattern is for, but there are 2 patterns on it
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    You mean that extra hole in the middle at the top? That's the only extra hole my '91 hydraulic bellhousing has, but it also appears on the 73-84 linkage bellhousing as well /forums/images/graemlins/confused.gif
    I'd assumed it was used to bolt up one of the side-loader trannies; either the 3-spd, or 3+OD.
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    There are only 4 bellhousings which will work with a GM NV4500.
    1: Stock GM bellhousing used in 93-95 GM trucks, with the slave on the passenger side.
    2: Stock GM bellhousing used in 96 and newer GM trucks, with the internal slave.
    3: Advance Adapters bellhousing, for GM NV4500s 92-95, adaptable to mechanical and hydraulic controls.
    4: Advance Adapters bellhousing, for GM NV4500s from 96-00, and all Dodge NV4500s, also adaptable to mechanical and hydraulic controls.
    Then theres adapter plates to bolt a Dodge NV4500 to a GM 5.125" dia. bellhousing.
    Hope that helps /forums/images/graemlins/thumb.gif
