NV4500 to NP205?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newboy89, Jun 21, 2002.
  1. newboy89
    newboy89 Registered Member
    Nov 18, 2001
    34
    Ny
    can it be done? and has anyone here done the swap form a 700r4 to a NV4500? cause i kinda want to have an idea of what needs to be done. and what kind of clutch does the NV4500 use?
  2. dyeager535
    26,980
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You'll need to 205 from 71-79 if I remember correctly with a 10 spline input. Then you'll need the "specail" 4500 to 205 adapter and shorten the 4500 output shaft to something like 4.49 inches. Which can be done by just removing the tailshaft housing and proceed to cutting. Then you should be set. Most likely the Hyd clutch setup will be the best for you. You can go to advanceadapter.com and order the 4500 conversion manual they have for $10.
    Hope this helps. Im in the process of doing the same thing, but may keep my 241 T-case. /forums/images/icons/grin.gif
