NV4500 tranny x member ????HELP!!!!
Discussion in 'The Garage' started by K5MONSTERCHEV, Aug 1, 2003.
  1. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Those of you who have put an NV4500 in your k5, what did you do to bolt it to the tranny cross member?? Mines a 72, the "adapter" they gave me doesn't even come close to mounting where it should. Am i going to have to move the whole crossmember back? HELP!!!!!
  2. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    i did some swapin along those lines in my k20 and the wole thing moved forward by couple inches, i just drilled new holes for the crossmember.
  3. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I also have done the NV4500 to 205 and just recently the NV4500 to ORD 203 to 205. I had to move the crossmember back a couple of inches the first time and used the tailhousing mount on the NV4500. This made it easier when I did the doubler installation as I could leave the transmission crossmember in place and install the 203 the the 205. I had to make a custom crossmember for the doubler mount once it was installed.
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    My 4500 sits on the stock mount and crossmember in stock location. Engine sits on stock SBC mounts and clears everything fine. Couldn't have been an easier swap. /forums/images/graemlins/smile.gif
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    k5......So did you drill new holes originally??
