NV4500 VS SM465
Discussion in 'The Garage' started by Batmanjr, Oct 12, 2002.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    How much harder will a 32 spline NV4500 be to install to a 6.2L Diesel than a SM465???? I have the 465 with the long adapter, but really want OD! The Rnger Box is WAY out of my budget and I might have a lead on a Nv4500 with the 32 splines and 205 adapter! What's your opinion and how much harder will one be vs the other to install!
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    From what I understand.... /forums/images/graemlins/tongue.gif
    It mostly depends on what year truck you have, and what year model 4500 you decide to pick up. If you get the 95 or later 4500 they will be more easily fitable for hydraulic clutch setups. But then again, some of that has to do with what truck your putting it in.
    It's not worth a whole lot, but I'm recommending getting the Advance Adapter NV4500 conversion manual. It's got lots of good info. And for $10... /forums/images/graemlins/thumb.gif
    Good luck..I'm in the build up stages for a 4500 swap myself. Hope your lead is not the same lead I have. /forums/images/graemlins/eek.gif
  3. Batmanjr
    Mar 23, 2001
    1,537
    No, my local junkyard doesn't know what it's worth!!!! I'd have to do a very physical check out but I think it's worth it! Have you thought about getting a Dodge 205 for the rear!??? It would bolt right up and work perfectly, I think!?
    My truck is an 83 Diesel with a 6.2L, soon to be modified to a 6.5L! How hard is it to get the GM205 with a long 32 spline on the rear??? I heard that I need another adapter for that, I'm about to buy stock in AA!!!! Any info you can give would be great!
