Nv4500
Discussion in 'The Garage' started by Green71, Dec 12, 2004.
  1. Green71
    Green71 Registered Member
    May 29, 2002
    26
    St. Clair, MI
    I wasnt sure but i thought the NV4500 came as standard equipment in the 2 door blazers and yukons from 92-96 (the automatic being an option)right? I think sometime after 94 they made the automatics standard with the NV4500 being an option. Then after 96 or something they didnt even offer the manual trans anymore in them. Please correct me if im wrong. Thanks for the info.
    -Chris
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    To the best of my knowledge GM offered the Getrag aluminium manual tranny in the Blazers in those years .
    Tom
  3. Green71
    May 29, 2002
    26
    St. Clair, MI
    Thanks. I wasnt sure what they had. Anyone have any info on the preformance of these trannys? Likes/Dislikes? Thanks again for the help.
    -Chris
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    It is not a "Heavy Duty" tranny but it does O.K. in half-ton truck useage. It has a fairly low first gear ratio ( IIRC around 4 to 1 range ) .
    If the fluid level is kept full and sane driving is normal it should last as long as the rest of the drivetrain in that Blazer.Just don't tow in over drive ( the counter shaft bearings can not take the added strain ) keep it in fourth gear while towing .
    HTH, Tom
