nv4500
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87GMC, Mar 2, 2002.
  1. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    The 465 needs rebuilt. Anyone convert to a nv4500? Where
    does the shifter line up?
    87 V1500 305 TBI 208/465 4" 35"procomp mt Dana 44/12 bolt
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I also would like to convert to NV4500 someday. My 465 is making disturbing noises, and I miss the overdrive that the 700R4 gives me in my other truck.
    I know of some guys who have done it, but it ain't cheap.
    I'll be watching this thread with interest.
    1986 K-10, 6.2L N/A diesel, SM465, NP208, 3.73 gears
    <a target="_blank" href=http://community.webshots.com/album/14911798DvydoACKJE>My Chevy Photo Album</a>
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I took a few measurements. My NV4500 has the center of the shift tower 9" back from the edge of the bellhousing. As near as I can tell the SM 465 is about 5" back from the bellhousing.
    The stock bellhousing for a NV4500 won't work in our trucks. The slave cylinder is on the passenger side and apparently will interfere with the front driveshaft. I plan on modifying a SM465 bellhousing...the alternative is a bell from Advance adaptors.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    I plan on going the advance adapter route. Just concerned about the trans shifter conflicting with the t-case shifter. Do you have your's installed?
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Nope...still rebuilding it.
    Sparky87K5 is running a NV4500 with either a 208 or a 241 in his Blazer. If he doesn't see this thread maybe send him a pm.
    rene
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    i think i have a spare mech linkage bellhousing
    formerly 77chev
    still a jerk though
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Cool, what do you want for it?
    Rene
  8. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I run the 208 and after moving the hole in the floor back 5" for the trans shifter, I had to move the TC shifter back about 3". Otherwise, the large 208 shifter cover is in the way of the trans cover plate and boot. I trashed the plastic 208 cover plate, kept only the rubber boot and made a new cover plate of aluminum for the boot. Very easy job, really don't need the plastic cover plate to tell you where you are in the shift pattern, at least I didn't. Looks cleaner too. Can send you a picture if you like. All in all, it's a pretty easy job.
  9. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    Thanks for the info. Any pictures would be great. I have the benchseat, so I also have to make sure the t-case will clear the seat. Did it affect you driveshafts, or is the overall lenth the same?
  10. Sparky87k5
    May 6, 2001
    726
    Will take some pics and post them for you. Stock K5 driveshaft worked fine for rear but front was shortened because I swapped in D60 and 14BFF at same time. My 14BFF uses same size U-joint as 3/4 &amp; 1/2 ton trucks, so no problem for stock driveshafts. Since then I have lifted my truck 4" and can still use stock driveshaft as a spare for emergency use only. Had a custom CV joint version built with dropped TC and rear axle pointed at TC. Still not perfect, TC leaks at slip yoke and have tried 3 different seals. Now plan on conversion to GM/Dodge 208 with bolt on CV joint driveshaft. I'll get those pics done today.
  11. Sparky87k5
    May 6, 2001
    726
    Here some pics of interior.
    http://216.185.99.68/35D8FF9FB51BB2F/standard.jpg
    http://216.185.99.68/E7494E49C89B945/standard.jpg
    Hope this helps.
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How hard was it to adapt the NP208 to the NV4500? What was involved? Nice work with the install of the shift, and stuff. It is very clean.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    for you, nothing
    if I still have it its yours
  14. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Cool...I'll call you later, if you're home maybe I'll swing by.
    rene
  15. Sparky87k5
    May 6, 2001
    726
    Any 32 spline 208 or 241 will bolt right up to the GM NV4500. I've been told that a late model 32 spline 205 with the circular bolt pattern will also bolt right up.
  16. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    Thanks for the help. Install looks great. Nice job with the gauges.
  17. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Be very careful about which NP205 you try to bolt up to the NV4500. I have a '91 crewcab with SM465/NP205 - this NP205 has about a 3" long female input shaft. It will not bolt up to the NV4500; the splines bottom out with the 205 and NV4500 about 2" apart.
    Also noteworthy is the need to notch the round flange on the back of the NV4500 for shift rail clearance
  18. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    umm, can i have your 465? /forums/images/icons/smile.gif /forums/images/icons/smile.gif
    just thought i would ask...
    Grant
  19. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    If you're serious I'll sell it to ya. Going to be near end of summer. Need to install gears and lockers first. Let me know.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is it possible to mate a fixed yoke 205 to an NV 4500?
