NWF 1" Zero-Rate Leafs $45 per set
Discussion in 'Vendor Forum' started by NorthWestFab, Apr 20, 2006.
  1. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    NorthWest FabWorks newest product. 1" Zero-Rate leafs. $45 per set
    These are 100% CNC machined billet steel and come with all the grade 8 hardware needed. These Zero-Rates will fix a sagging rear end or get that extra lift needed in the front. Since these bolt through your leaf pack and are not blocks they can be safely used on your front or rear axle. They are also drilled to allow axle relocation 1" or 1.5" forward or backwards.
    For installation you will need to have 1" of extra thread on your current U-Bolts or you will have to purchase new ones. If you are using the axle relocation feature you will have to redrill your U-Bolt plate. Another thing to keep in mind, if used with cross over steering your leaf pack will be 1" taller. NWF carries the tallest one peice steering arm available on the market if you need that extra bit of clearance.
    -The Guys,
    NorthWest FabWorks
    250 248 6024
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    did the center pins come from a local supplier? im having a hard time finding pins that long threaded that far down. only ones i can find have a 1.5-2 inch shoulder. at least locally.
    btw thats a great price. hard to beat that, buying your own steel and making them yourself. looks great. keep up the good work
  3. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    Is it just the picture or are those angle milled?
  4. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    Ryan,
    Those are the type that we normally carry in stock I can get you a set or two if you need some. PM me and we can figure it out.
    Old,
    Just the picture but we would be able to offer them in a custom tapered version if people are interested.
    Jordan
    NWF
  5. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    Whats the lead time on these 2, 3 weeks? Eric
  6. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    We have 15 sets on hand.
  7. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Is that in Cdn funds and how much would you charge to send it to Ontario with Can.Post? Thanks.
  8. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    $52.00 CAD + $12.00 Flat Rate Canada Post (GST Not Inc.)
    Give us a call @ 250 248 6024 and we'll get you set up.
    -Jordan
    NWF.
