o.k I found more problems?? Now water in both differentials???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Feb 7, 2001.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    o.k I am just having a terrible week, I get a custom built drivshaft go to put it in and snap a bolt on the yoke, so I take out the yoke to replace it, since I got another one cheap. When I pull it out what do I see, water in with the gear lube. So I decide to check the front, smae thing? Where is it coming from, I have all of the vents, ran with tubing into the engine compartment(up high) with a filter. My pinions seals dont leak. I am wondering if it could be coming in the axel seals?? Where are the front axel seals located?? are they inside the tube?? Any sugestions are welcome.... THanks
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Yup the front seals are inside. you have to remove the carrier to get at them. do you have any signs of leaks?? Make sure all your vent tubes are not picking up water in the eng. compartment too.
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    If your vents are not cracked and not plugged, then you have a seal problem. Did you play in water? Anyways, the culprit is the axle seals you mentioned. They are located in the differential right by the carrier bearings. In other words, they are in the pumpkin. To change them, you need to take out both shafts completely out. You would also have to take the ring gear/carrier assembly out too. Make sure you keep everything in order, including the carrier caps and bolts. Contrary to what some people say, the seals are NOT out in the end of the tubes by the knuckles. They are in the inside part of the tubes.
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yep its the seals and they r pretty easy to change out. Do what "thatK30guy" said. New axle seals r gonna cost you a whapp'n .50cents a piece. Just an afterthought if you dont have manual hubs now would be a great time think about the investment.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
