O-Rings/Fittings for Steering box...
Discussion in 'The Garage' started by 90blzr, Apr 2, 2005.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Does anyone know if you can buy the O-rings for power steering lines/box seperate? The ones that are used where the lines enter the steering box. My lines dont have the O-rings on them, and I cant find the fitting for the return side. I went to auto zone and the guy said I had to buy the whole hose assembly.
    And the fitting that goes into the box....he said they dont sell that? Havent had time to check elsewhere yet.
    Does the 'return' side have an o-ring also...or just the fitting itself into the box?
    Thanks!
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    someone correct if i'm wrong on this please..
    i just went thru this... i believe they are saginaw fittings... the return line is also one, just a smaller size then the pressure...
    i had to get the return line from the stealership and bend it myself.. think it was like $12...
    they are just standard O-rings... i'd bet our generic o-ring selection box has the same ones but i haven't checked.. thats a good reminder, i meant to throw some of those in my spare parts crate i keep in the truck..
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Either go to the dealer for the Orings, or your local hydrualic shop. The pump will have a nipple on it for the return so if your box has the metal line coming off it already, then just use 3/8 I.D. tranny line and hose clamps.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can go here : [​IMG]
    Lee Manufacturing Co.
    11661 Pendleton St.
    Sun Valley, CA 91352
    818/768-0371
    and then use older hoses via these adapters , then no more o-ring issues :k5: :k5:
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    the oring style boxes use the same fittings as the oring fuel lines that rust out. just ask for the propor size fuel line repair section and dont tell them its for p/s line.
