O/T fuel system ?
Discussion in 'The Garage' started by skratch, May 21, 2004.
  1. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    I know this is a bit off topic, but . . .
    I got out my lawnmower yesterday and went through and did a full tune up on it so I could mow the yard.
    After two hours of work trying to figure out why it wouldn't start I tried to see if it was pulling air into the carb and once my fingers blocked the intake it started!?
    I could only get it to run if the air intake was blocked almost entirely /forums/images/graemlins/dunno.gif
    It seems that it is geting too much air with the choke closed as far as it will go.
    Does anybody have any idea what the heck is going on and how to fix it. /forums/images/graemlins/1zhelp.gif
    Oh yeah it's a Briggs 6hp that has otherwise always run great.
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Maybe your mixture screww needs adjusted. Sounds like you're getting too much air. Maybe your mounting gasket is blown or the carb has come loose. I used to run go-carts with 5 HP B&S engines and they vibrate like a Harley, seems like something is always coming loose.
  3. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    I went through and resealed all the gasket surfaces thinking it might be a leak, but I'll definatly look at the mixture screw.
    I kinda thought it was running rich, thanks!
  4. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    If it wouldn't start until your fingers blocked he intake it was probably sucking a little too much air and you fingers acted like a choke plate. Those engines can be funny little turds though. /forums/images/graemlins/dunno.gif
