O.T.-S-10 transfer case...which side is the fron output shaft
Discussion in 'The Garage' started by BobK, Apr 5, 2005.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    O.T.-S-10 transfer case...which side is the front output shaft
    As the title says.
    Is the 4x4 S-10 transfer case a driver's side or passenger side drop to the front axle?
    And did they ever come attached to a TH350.
    I ask as my brother in-law wants to swap in a SBC 350,TH350 into his 88 YJ(Jeep) and we're trying to figure out what transfer case we could use.
    Thanks,sorry for the Jeep related question.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    s10s are driverside drop. they were only behind 700r4, but can be easily adapted to a th350, the 1.75" spacer.
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Cool.
    You have a link to where I could find that spacer?
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i just remembered, with the th350, you need the 2wd short tail (6" tailshaft) and cut 7/8" off the end (IIRC) then you can use the spacer to hook it to the tcase. it will be the same length as a 700r4 though.
    a link to the spacer has been posted before, im too tired to look for it.
  5. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    no problem man,thanks for the info anyways.
  6. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you might want to think about a t case from a full size because a lot of times the transfer cases used in the s-10 can not handle a lot of torque
  7. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Trying to do this on a budget.A full size T/C will exit the passenger side,won't it.
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    not one from a newer IFS truck
  9. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Hmm...something to think about.
    Thanks!
  10. joshua632
    joshua632 Guest
    jagsthatrun.com has everything you could possibly need for this swap. check it out!
