O2 Sensor on 87 with tbi
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CJeepFreak84, Apr 17, 2003.
  1. CJeepFreak84
    CJeepFreak84 Registered Member
    Jan 13, 2003
    32
    Northern New Jersey
    Any one know the location of the o2 sensor on 87 tbi? looked in hayes and ended up being burned by burning hot coolant by accidentally taking out the temp sensor? on the drivers side of block.... Thanks
  2. Grim-Reaper
    7,385
    Atlanta
    It's in the exuast manifold near where it joins the exhaust pipes.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Driver's side exhaust manifold. Points toward the back of the truck IIRC from working on the neighbor's '88.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yup, and it's a b!tch to get at, let alone turn a wrench. /forums/images/graemlins/mad.gif
    CJeepFreak, yeah, that was the coolant temp sensor for the gauge that you took out.
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Suggestion...SOAK, and I mean SOAK the thing with PB Blaster Catalyst before you try to take it off. Mine wouldn't budge till I soaked it for a day.
  6. CJeepFreak84
    Jan 13, 2003
    32
    Northern New Jersey
    well at least i was on the right side of the engine /forums/images/graemlins/laugh.gif thanks for the advice... i know it was an easy question but that thing is really hidden in there!
  7. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I'd buy a spark plug tap(same thread as an O2 sensor). Every O2 sensor I've replaced I've taken most of the threads out with it and weren't able to start the new one, and since this one is in a bad spot (what O2 sensor isn't?) I'd buy the tap and it'll go much faster/easier.
    Ben 87 Jimmy + 89 Blazer
    /forums/images/graemlins/usaflag.gif
  8. bigtruck87
    bigtruck87 Registered Member
    Mar 19, 2003
    33
    Treton, NJ
    in a tight spot you say? i am a tech at a lincoln dealer and compared to a licoln nothing on my 87 blazer is in a tight spot.
  9. CJeepFreak84
    Jan 13, 2003
    32
    Northern New Jersey
    well i'm leaving it in fornow.. i've got to get the valve seals cahnged ithink.. (burns oil) so i don't want all the oil fouling the new sensor...
  10. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    /forums/images/graemlins/burb.gif
    It was a piece of cake to replace on my 87 burb. Turned right out, with a little liquid wrench, and mine had never been out before either.
    Why are ya replacing it anyways?
    It's easier to get at from under the truck than it is from above.
  11. CJeepFreak84
    Jan 13, 2003
    32
    Northern New Jersey
    just basic tune-up... first one i've done on it... i'm going to wait till i get the valve seals changed anyway.. i don't want the new sensor getting all clogged with oil
