O2 sensor...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Jul 10, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    How do you know if the O2 sensor is bad or not. I dont know how long it has been since mine has been changed, at least a year cause I havent done it. Anyways is it just something you replace with every tune up or is there a way to tell if it is good or bad? And it is located on the exhaust manifold right and is there only one? What does it do exactly anyways(might be a dumb ?, but I wont know unless I ask) Getting ready to do the normal tune up stuff and was just wondering about that sensor. Thanks.
    <P ID="edit"><FONT SIZE=-1>Edited by 90blzr on 07/10/01 10:13 PM (server time).</FONT></P>
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I like to replace them whenever I do a tune-up - a good rule of thumb is every 50K miles. There's really no way to test them at home, so I'd say just chunk it and replace it.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    They're cheap too.
    "I am Republican. Not a baby-killing, tree hugging, land grabbing, touchy feely, hypocrite wuss democrat!"
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    If it's bad, the computer will throw a code, 13 I think, but I'm probably wrong.
    But it is a good thing to change with every tune-up. It loses accuracy after some mileage...
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**<P ID="edit"><FONT SIZE=-1>Edited by newyorkin on 07/11/01 07:56 AM (server time).</FONT></P>
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I believe you are supposed to change the O2 sensor when you put a new CAT on. I'm sure you should do it more as well but deffinitely with a new CAT. I just pulled mine and I could tell by looking at it that it has seen better days.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</A>
  6. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    the manuals recommend replacing it every 60,000 miles...
  7. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Every 60k is about right for replacement.
    The O2 sensor is located in the manifold or headers and you should have only one of them. The ECM uses the data from the O2 sensor to set the air/fuel mixture on your TBI.
    If the O2 sensor goes bad, the 1st indication will be a noticable loss in fuel economy. The computer will not always throw a code when the O2 sensor goes bad; Sometimes it will, sometimes it won't.
    On my camaro, I got a code 44 (lean mixture) from a bad O2 sensor. The sensor gets clogged up and starts reporting that the exhaust is too lean. Because of this, the ECM will compensate by making the mixture too rich. This is why your MPG is the first thing to suffer from a bad O2 sensor.
    If you think it's bad, just replace it. They're cheap enough.
    Thomas.
    -- '84 K5 Blazer --
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Got a propane torch, and voltmeter ?
    If yes then you can test them at home !
  9. Executioner
    Feb 22, 2000
    1,530
    You must have one of those calibrated eye balls !!!!!!!!!!!!!!!!!!!!
    NOT
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have always used an occilliscope to test them. Every time I've tested an old one, it's bad. Replace it, re-test, and it puts out the proper waveform and works wonderfully.
    Tim
  11. dyeager535
    26,980
    Use a GM one. Heard nothing but bad news about the aftermarket ones (Bosch, etc.) although some I'm sure have had no problems.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  12. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    If you pull it out to test it then why not spend the $12 and toss in a new one?
  13. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    $12???? Where do you shop?? Mine was $30 2 months ago up here on Long Island!
    Ratch
  14. rampage
    Mar 20, 2001
    2,261
    73
    $30? Hmmm, don't remember paying that much, but I bought mine about a year ago so my memory could be slipping.
  15. Executioner
    Feb 22, 2000
    1,530
    can you plese describe the waveform ?
    TIA
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    We didn't pull them out to test them. We probed the wires. How could you test if it was working anyway unless the engine was running.
    Executioner,
    The waveform looked like a sine wave. It would go lean for a split second, the computer would make an adjustment, it'd go rich, then make another adjustment, etc. The bad ones didn't make any waveform at all. The shape of the waveform wasn't all that important, as long as it showed that the sensor was operating. Like I said earlier, none except the brand new one ever registered a thing.
    Tim
  17. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Just replace it... you don't know for sure if it was replaced or not before you got it. Chances are not... they are like $30-$35. It can make a difference in how your truck runs.... I just bought one, it's by Standard. I'm replacing my whole exhaust and figured it was time! Get a new one and then you can be sure it's working right....
    BTW I have an 86 and the part # is SG5. I'm not sure it'll work for you, but if it does then you could use it [​IMG]
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  18. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I sense the sarcasm... but majority of my blazer still had factory goodies under it when I bought it. And this O2 sensor was looking pretty bad. Granted yes it might have still been good... but I highly doubt it.
    89 K5 Silverado
  19. Executioner
    Feb 22, 2000
    1,530
  20. Executioner
    Feb 22, 2000
    1,530
    It is ok to replace parts that look bad ! But its more fun to test them first, with home made tools !
    And learn from it, wish I could afford to replace all bad looking parts on my K5.
    Keep up the good work, its all part of the learning process.
    Good luck
