O2 sensors and headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Jul 28, 2002.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Ok, I know this was on here somewhere search cant find it.
    I have a 350 TBI that I am going to install a set of dynomax headers on. where should I mount my O2 sensor? /forums/images/icons/confused.gif TIA for the help.
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I put mine in the collector right behind the header.
  3. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    im mounting mine right behind the collector...thats where everybody has told me to put it
    Later
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Just finished mine, same as above, works great.
  5. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanks guys. WIll have to make the mod. this week. Did you guys get you weld bung from a parts store or did you find the right size nut? What is the size ....dia. and thread count?
  6. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I ordered mine from jegs when I got my headers.
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Just get a spark plug non-fouler from the Help section and cut the end off. This is what my dad and brother did and it worked fine.
    Has anyone had a problem with one side running too rich with a true dual setup? My brother has true duals with headers and the pass. side is running bad but the driver side, w/ O2 sensor, is fine.
  8. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Is it tuned port or tbi? Some tuned port systems used two o2 sensors. Not sure what it would be if its tbi.
  9. fr8train
    Aug 2, 2000
    1,712
    Maryland
    The both engines that I have never had an issue with that. Both are/were run with true duals. Tbi engines with only one O2 sensor though.
  10. dyeager535
    26,979
    My thinking is that it can't happen unless something is wrong with the injection system itself. ECM still "thinks" its seeing both sides of the engine, so it will richen or lean based on the side with the O2 sensor.
    So what happens to one side happens to the other, barring electrical/mechanical problems.
    Only issue I can think of is teh O2 sensor is looking for 8 cylinders instead of 4, and would see a lean condition all the time. But I assume, striving for that 14.7:1 mix, whether 4 cylinders or 400, if its 14.7:1, the O2 sensor will be happy.
  11. andrey busurgin
    andrey busurgin Registered Member
    Jul 24, 2002
    14
    Russia
    All engines GM with which I dealt, had a thread of gauge O2 - M18x1.5 (mm) /forums/images/icons/smile.gif
  12. andrey busurgin
    Jul 24, 2002
    14
    Russia
