o2 sensors
Discussion in '1992-Present Chevy & GMC models' started by willyswanter, Sep 29, 2002.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ok, I have a 96 with vortec 454 and 4 o2 sensors. 1 before each cat, and one after each cat, with two cats. Ok, the bank 2, pre-cat sensor is failing and throwing my fuel delivery on that bank way off. My question is, can I take a post cat sensor and switch it out with the problem pre-cat sensor to get my fuel delivery back on track till I can buy a new sensor? Or are the pre-cat and post-cat sensors different?
  2. finnd
    finnd Registered Member
    Dec 27, 2001
    65
    Northern Virginia
    i think some of your o2 sensors are heated, while others are not. I imagine a simple check on part numbers for the diferent locations would tell you if they can be swapped.
  3. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    jason, i'm pretty sure the sensors would be the same front or rear. if you needed to check that, just call and ask the parts guy at the store if they have the same part #s for the front and rear.
  4. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    No, they are different, at least the connections are. On my '96 350 the plugs front to rear are differnet. Expensive suckers too!
