OBA Question (not York)
Discussion in 'The Garage' started by sarasotausmc, Nov 17, 2006.
  1. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    So, the wife drives a 99 Olds Silhouette van that has an self leveling rear air suspension (stock). I can't seem to find any info about the system online except that the compressor is about $350 from GMPartsDirect and it seems something like that may be a viable option for OBA. I've seen a ton of those vans (or similar GM models) at the junkyards and was wondering if anyone knows if it would be worth experimenting with or not.
    The compressor in her van maintains/adjusts the rear suspension and has an outlet for airing up tires/inflatable beds, etc and seems to have a decent CFM (no idea what PSI it puts out). Plus, it's 12V with it's own relays and pressure switch, as well as aux air on/off connection and switch, plus it's small enough to be hidden behind the interior panels of the van.
    Any input?
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    i tried using one from a caddy once and it did not work. It couldn't put out enough CFM or pressure fast enough.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    My wifes expedition has the load leveling rear also, so if you are pulling one from a yard it might be an option.
