OBA question
Discussion in 'The Garage' started by 77crewcab, Aug 24, 2004.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I would like to add on board air for tools, airhorns, and some airbag helper springs and have a question. I have read the York instal write up and will probably try to go that route for a nice budget build. But I saw an alternative on a rerun of TRUCKS! yesterday. It showed an electric compressor kit from Extreme Outback, but when I went to their website I saw that they also have a engine mounted, belt driven compressor. I was wondering if anyone had used this before or your thoughts on this unit. Also I was thinking of using their accessories to set up the system (air tanks, relays, pop off valve, etc.) What would be a good place to look for budget alternatives to these. Home Depot or something like that?
    Thanks alot!
    Edit: Forgot to add address http://www.extremeoutback.com/
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that is the compressor I got from an Astrovan with a 4.3
    bolts right up using the 4.3 bracket to my 77 chev 350
    I paid $14.95cdn plus 14% tax
    I had to use a waterneck and upper rad hose from a fullsize Van to clear it, hose size depends on the year so look for the waterneck to match
    I used 77 van upper rad hose part number
    this is simple stuff and dirt cheap
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    What? /forums/images/graemlins/confused.gif Sorry you lost me on that.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    can be found on Astrovans at the wrecker for $15cdn
    but you will have to paint it red yourself
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what did you do about the oiling, or do those have separate oiling like the york?
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    has a reserviour
    see the top plug that they modified by adding a grease nipple?
    that is fill plug, drain is on the rear face under the air in/outlets
    compressor has 'York' in big letters and some asian name in the fine print
  7. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Oh okay, so what year Astro did these come on? What were they used for? Air system or a/c compressor? Their website had a mention of these being used on the Military Hummer so it would be really cool that they also came on a simple minivan.
  8. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    mid 80s AC
  10. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    MJ, do you happen to have any pics of the bracket setup? I am curious if it would clear my brackets on my LT1.
  11. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    So what did you do for oiling? grease zerk like the pic or use actual oil lines? Astros started in what 85?
  12. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I'd be interested in pics too. I just searched through the partsamerica.com websites looking at the a/c compressors for Astro and none of the compressors look like the pic above. Infact I even looked at several different GM cars/trucks of the same era and they all use the same type of a/c compressors and none are like the picture above. So a picture of what you have would be very helpful.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what year LT1?
    I grabbed the older V belt Astrovan one to match my 1977 engine
    mounts above PS pump on driver's side
    I also grabbed a dual V water pump pulley off a random GM Cutlass/Malibu type 80s car and a water neck from a fullsize van
    while I was on the FS van I grabbed the PS pump brackets and remote style res from one as well
    no digi camera now so SOL on the image guys
    I was Pick-A-Part cruising and saw these.
    summer sale $14.95 for any AC compressor
    also found one on a 351M ford van that will go on the 79 bronco project
    the rear fittings differ slightly from the red image
    there is a small threaded cap about tire valvestem size facing forward under each fitting
    I am using oil, not sure why they chose to use a grease nipple there
    next time I will grab the matching pressure switch from the accumulator rather then hunt one down later
    the one from the ford has an adjustment screw under the wire plug
  14. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    94 LT1. Those engines have a completely different bracket and pulley system than any other SBC, with all accesories primarily on the passenger side and the drivers head mostly free. I wonder if that compressor on the Astro is Canada only? I am also thinking of a 70's long compressor. I have read on PBB of good results with those for OBA.
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    pretty much any AC compressor will work jus' fine
  16. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    So does that mean that I could just use The same style a/c compressor that I already have (77 style about a foot long) for my onboard air project? BTW I figured out that the pic above is the same style compressor as used on the Volvo by looking at pics on partsamerica.com forget whick series though.
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Biggest problem with using just any old air compressor from an AC application is many of them do not have lubrication for the pump seperate of the Freon. Eventually you burn up the pump. Pictured above it has a fill plug for pump lubrication so its much better for onboard air.
  18. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    So should I just look for the york off the volvo? I went to the yards around here yesterday and couldn't find any on the Astro. The Extreme Outback setup looks really good but not sure if I would want to spend that much money just to have new parts.
  19. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Yorks are popular b/c they have their own oil sump. Burning them up isn't as likely as with a rotary type like the pic above. The York's I've seen on Volvos are some of the smallest York's made. I'd look for a full sized anything with a York for the donor. If you can find one off a motorhome that would be even better. Do some searching as the way to ID the 3 different common York displacements is well documented.
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it would be kinda Jeep to get a compressor from a Volvo to go on a Chevy
    smarter idea would be to get a compressor from a chevy that bolts up with no fabrication
