OBA tank question
Discussion in 'The Garage' started by MTBLAZER89, Feb 9, 2005.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    It *should* work, though they don't specify what it is rated for. It would however be a lot cheaper if you pick one up from a semi wrecking yard. I pulled a 5 gal with 7 ports from the brake system of a freightliner for $10. No shipping either.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    anybody else?
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Brian,
    If it's rated, it would work out just fine. Lots of capacity, and the 4 ports make it real easy. Drop the seller a line on ebay, and ask him what the tank is rated for. I would jump on it if it's rated.
    Rob
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Rated as in the PSI limit?? What "should" it be rated at?
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Brian, my 2 air tanks I got off ebay. They are both 5 gallon low rider hydraulic tanks. Mine have 8 ports each.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I would want at least 200 psi, I think , im not shure but i think you want the rating of the tank to be like 20% higher than the output rating of your compressor
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    What are they rated at? I have no idea what my york put's out? Sweet they have them in chrome too...some steel braided air hose then a chrome impact, and I'll be set.:D
  10. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, maybe chrome COULD get you home...:thinking:
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    :thinking: :thinking:
