OBD II code help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lugnut, Aug 30, 2005.
  1. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    Anyone know where I can find somthing explaining what might cause a code? I have a P0420 on a 2000 Sunfire with a 2.2L and I need to know what the cause might be. O2 sensor , cat , O2 sensor after cat somthing else ? Mods sorry this is not a truck but it is tech and the info could also be used on a truck. Thanks Allen
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I will look it up in the TEC2 book and post up all the info i can find
  3. readymix
    May 30, 2004
    6,706
    26
    Sensed Parameter
    - Catalyst Monitor AMT
    Faulty Code
    - P0420
    Monitor Description
    - Detects a catalytic converter with unacceptable amounts of oxygen storage capabilities
    Critera and Thresholds
    - Oxygen Storage Capability (OSC) Time Difference > 0.182 sec
    OSC Time Difference = OSC Worst Pass
    Thresh - OSC Compensation Factor * (O2S 2 Response Time - O2S 1 Response Time)
    OSC Worst Pass Thresh = 1.820 sec
    Secondary Parameters and Enabeling Conditions
    - Engine speed > 1000 RPM for minimum of 34 sec since end of last idle period
    Predicted catalyst temp > 345C, < 450C
    Baro > 72.3 kPa
    IAT between -20.5C & 80C
    ECT between 70C & 125C
    Idle < 45 sec
    MPH < 3
    Test attempted this trip < 12
    -75 RPM < (Engine Speed - Desired Speed) < 150 RPM
    Engine run time > 520 sec
    Battery voltage > 9 V
    Flow < 7 g/sec
    Rapid Step Response Enable Criteria
    OSC Time Difference Step > .590 sec
    OSC Time Difference Step > 0.00 sec
    None of the following DTC’s set:
    105, 107, 108, 112, 113, 117, 118, 122, 123, 131, 132,
    133, 134, 1133, 137, 138, 140, 141, 171, 172, 200, 300,
    325, 336, 340, 341, 440, 1441, 442, 446, 452, 453, 480,
    481, 502, 503, 506, 507, 601, 602, 1621
    There is also a sedondary test ran which can also set this code. From what i am reading it just varies the thresholds and conditions too check the system again.
  4. lugnut
    Aug 3, 2001
    268
    North Carolina
    :doah: My head hurts now. So are you saying the computer is comparung the readings from the O2 sensor before the cat to the O2 sensor after the cat ? I had the cat replaced about 5,000 or 6,000 ago.
  5. readymix
    May 30, 2004
    6,706
    26
    But did you replace the O2's?
  6. lugnut
    Aug 3, 2001
    268
    North Carolina
    No. I was trying to save some cash.
