OBDII code 1345 question.
Discussion in 'The Garage' started by MOABDADC22, May 2, 2004.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    See this post.
    Once again, any help is appreciated.
  2. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Someone....... anyone??????? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    could it be the timing chain has a little extra play /forums/images/graemlins/dunno.gif since there is a correlation between cam and crank.
    just a thought,
    ARQ.
  4. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    This is from my GM Service Information Software. I have the same code after changing intake gaskets.
    Conditions for Clearing the MIL or DTC
    The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
    A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
    Use a scan tool in order to clear the DTCs.
    Diagnostic Aids
    Check the following items:
    A loose CMP sensor causing a variance in the sensor signal
    Excessive free play in the timing chain and gear assembly
    Incorrectly installed distributor - 1 tooth off in either advance or retard positions
    A loose distributor rotor on the distributor shaft
    A loose or missing distributor hold down bolt
    An intermittent may be caused by any of the following conditions:
    A poor connection
    Rubbed through wire insulation
    A broken wire inside the insulation
    Thoroughly check any circuitry that is suspected of causing the intermittent complaint. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
    If a repair is necessary, refer to Wiring Repairs or Connector Repairs in Wiring Systems.
    Test Description
    The numbers below refer to the step numbers on the table.
    This test will determine if this DTC is intermittent.
    When the engine speed is raised to 2000 RPM the camshaft retard offset should not vary more than 2 degrees.
    If excessive pressure is used when performing this test unintentional damage to the distributor shaft could result.
    If the distributor is one tooth off in either the advanced or retard positions the vehicle may run but 0 degrees camshaft retard offset will not be obtained.
    If 0 degrees cannot be obtained during this procedure refer to Diagnostic Aids.
    Step
    Action
    Value(s)
    Yes
    No
    Important
    Before clearing the DTCs, use the scan tool Capture Info to save the Freeze Frame and Failure Records for reference. The control module's data is deleted once the Clear Info function is used.
    Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
    Go to Step 2
    Go to Powertrain On Board Diagnostic (OBD) System Check
    Install the scan tool.
    Start the engine.
    Use the scan tool in order to monitor the engine speed.
    Does the engine speed fluctuate (up to twice the desired RPM)?
    Go to Step 3
    Go to Step 4
    3
    Replace the Crankshaft Position Sensor. Refer to Crankshaft Position (CKP) Sensor Replacement .
    Is the action complete?
    Go to Step 10
    4
    Perform the Camshaft Retard Offset test procedure as follows:
    Start the engine.
    Important
    The camshaft retard reading will not be accurate below 1000 RPM.
    Raise the engine speed to the first specified value.
    Monitor the camshaft retard with the scan tool.
    Is the camshaft retard reading within the second specified value?
    1000 RPM
    -2° to 2°
    Go to Step 5
    Go to Step 6
    5
    Note the camshaft retard reading from the previous step.
    Does the camshaft retard reading change more than the second specified value?
    2000 RPM
    Go to Step 6
    Go to Diagnostic Aids
    6
    With the engine at operating temperature and the engine OFF, perform the following procedure:
    Remove the distributor cap.
    Grasp the distributor rotor and gently attempt to rotate the rotor.
    Does the rotor turn on the distributor shaft?
    Go to Step 9
    Go to Step 7
    7
    Check for proper installation of the distributor. Repair as necessary. Refer to Distributor Installation in Engine Mechanical.
    Did you find a problem?
    Go to Step 10
    Go to Step 8
    8
    Perform the Camshaft Retard Offset adjustment procedure as follows:
    With the engine OFF slightly loosen the distributor hold down bolt.
    Start the engine and raise the engine speed to 1000 RPM.
    Using the scan tool monitor the camshaft retard offset.
    Rotate the distributor as follows:
    To compensate for a negative reading rotate the distributor in the counterclockwise direction.
    To compensate for a positive reading rotate the distributor in the clockwise direction.
    Repeat step 4 until 0 degrees offset is obtained.
    When 0 degrees has been obtained turn OFF the ignition and tighten the distributor hold down bolt.
    Did you obtain 0 degrees camshaft retard?
    Go to Step 10
    9
    Replace the distributor. Refer to Distributor Replacement in Engine Electrical.
    Go to Step 10
    10
    Using the scan tool, clear the DTCs.
    Start the engine.
    Allow the engine to idle until the engine reaches normal operating temperature.
    Select DTC and the Specific DTC function.
    Enter the DTC number which was set.
    Operate the vehicle, with the Conditions for Setting this DTC, until the scan tool indicates the diagnostic Ran.
    Does the scan tool indicate the diagnostic Passed?
    Go to Step 11
    Go to Step 2
    11
    Does the scan tool display any additional undiagnosed DTCs?
    Go to the applicable DTC table
    System OK
    © Copyright General Motors Corporation. All Rights Reserved.
